There is no such thing as too much overkill!
exactly! you need more woofers
Ok, here's the last update, and it might be the very last thing I do with this system.
The news are:
Hypex Ncore amps - two driving the RD-75 ribbons, and four driving the woofers - and now there's sixteen of them.... a few pics without front grilles on the woofers below.
Your insane
If it's worth doing, it's worth overdoing!
Have you seen something like this before?
Oh yes, this is the best version if my dipoles when they still had baffles. My good friend Lars is the owner of these. In fact - he was the one that got me into building dipoles in the first place.
They have integrated Class-D amps mounted inside the woofer U-baffle. All that's needed in addition to these active speakers is a multichannel audio interface (like my RME Fireface, you see it lying on the floor there), and a computer to run the XO and EQ filters. Very neat setup indeed, and whow... it sounds great!
HI
I would like to build these speaker above with these drivers:
http://www.tb-speaker.com/detail/1230_04/rt-1516sb.htm
http://www.tb-speaker.com/detail/1230_04/w8-1808.htm
Eminence Alpha 15A speaker. The Eminence Alpha 15A is a 15" 8 ohm speaker for all bass applications. Alpha-15A is a 200 watt RMS 15" woofer.
How can I do?
how to build the crossover?
thanks in advance
Joined 2009
- My open baffle dipole with Beyma TPL-150
