Yes it can , use the wifi/bt USB inputHi,
Does this mean no USB drive can be connected with a USB DAC connected at the same time? That's a bummer.
Just registered as I'm very interested in the USbridge Sig + Shanti in alu case (so have to wait a bit longer).
It will feed a Kii Control (part of Kii BXT System) using USB, could also use coax but don't see the benefit in that.
I'll be playing music from NAS or Spotify -> but it's unclear what OS I should select? Has to be wife friendly. Today I have a minipc (atom) with Daphile and with spotify connect it's easy enough.
Hello,
Just got the Shanti and it’s improved the sound of the Digione sig.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I’m debating taking it apart and putting it and the digione into a single enclosure.
Are there obvious power in points on the digione so I can hard wire them together?
I noticed you also have the usb sig and it looks like there are power in points on that. If I get the usb sig, put the digione sig on top of that and get rid of my pi, will I still need both power outs of the Shanti?
mdr
mdr
Can use with digi one 40pin over USB bridges ?
Anything that works on RPI will work on USBridge Sig (RPI connector)
So..yes.
WIFI dongle we will have a new one in about 1 week. BT dongle I dont have a date yet
So..yes.
Thanks! I'll have to wait for case and Wi-Fi dongle.
Hi
Digione Sig needs 2 powers. "Dirty side" can be taken from USBridge DC input and clean side has to be feed independently
So yes you need 2 PSUs. You could tie them up together but we do not recommend .
Katwax , I would recommend Moode
What about the power in on the DigiOne sig, I'd like to hardwire the PS.
Thanks!
Hi
Ok thanks. No I wait for the bundle to be put online
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
