Simplistic mosFET HV Shunt Regs
Yep Salas you are my man🙂, I can use these two nice HIF2000 boxes for my 26 preamp😉.
Felipe, if I were you I'd rather use a pair of Galaxy Maggiorato (8 cm high). More space inside and alu sides big enough for Coleman's regs and SSHV2 (I think)
That's what I'm planning to use 😉
P.S. La Porxada, is that a nice place for tapas? 😀
You can just buy the missing pieces, if you wish. Basically you keep the top and bottom cover and buy front/rear panels and a couple of sides.
The galaxy 4 cm is sometime a bit too slim even for solid state projects. That's why I keep on asking them to design a 6 cm high galaxy series, nearly perfect for everything 😉
It may be because of the standard rack mount spacing that you get the 4cm high . the 6cm is odd at 1.5 rack space so a 8cm is more likely to happen . Or at least that what it looks like to me.
Thank you for the advice Massimo but it is not worth still having me with free pieces. I am going to ask for a new box with 8 cm of height but first of all tomorrow I have to check if the 8cm tall will be enough for 1 power tx for B+, 1 choke, 1 tx for AZ1 filaments and 2 txs for Rod Coleman heaters regs.
Not inside, I dare say. I put the pw Xfrm (HV + Rectifier Fil) and the choke on the top and the two big Xfrms for Rod's reg inside. Then I have rooms for all the caps.
Going to take some pics when I'll have time.
Yes I count to put all txs outside, but my mains power tx for B+ is a Bartolucci double C-Core & choke is also Bartolucci so both are big & heavy, I will post some pics tomorrow.
Salas sorry for OT.
Massimo if you want we will follows by pm or email.
Cheers
