Pavel Dudek made higher VAS rails in his amplifiers 17 years ago.
PMA, no see, I used this for measurements amplifiers later than 30th years ago.
Have a nice morning.
I use an amp, almost exactly like this, as my principal amp in my video system. It works well for this application!
Thanks for your input, John.
I am certainly not criticising at all... real world meaurements speak volumes, and I wish we could see more from people rather than just endless simulations.
This is a prototype HEXFET amp with no output inductor into 2.2mf at 20Khz at 20 volts peak to peak output.
Keep up the good work... it's an excellent design and very "tweakable" if that's the word![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Keep up the good work... it's an excellent design and very "tweakable" if that's the word![]()
That it's seemes better than Pavel amp.
But can you put here a photo for 10 KHz 10 Vpp square wave signal as same Pavel's signal? Then its are more comparable
Francesco.
Hi Francesco and Danhard,
Yes into 2.2 mf![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I can go a lot better than that too... have a look at the picture on post #4 here, the shot at the left. Virtually no ringing at all.
http://www.diyaudio.com/forums/soli...-hexfet-poweramp-sonic-benefits-approach.html
this was the amp used in the test's... different configuration to Pavels, but very valid non the less.
Yes into 2.2 mf
Can you tell us PMA?
PMA is in the sinbin for a week.
- Solid Solid State Power Amplifier
