Let me clarify my last post: those are sonic impressions. I do not like damped cabinets as they tend to sound like they're obscuring small details and just subtracting from the music. Whereas I feel these effects significantly less than with speakers based on the inert cabinet model.
I believe the BBC suggested 400Hz or so as the hard/soft transition. I'm building a baffle out of steel channel (C section) for below 300Hz. It will be down firing if I can get that to work, and have hardwood accoutrements, such as magnet clamping. No idea what to expect, but there are several places I can decouple or load the panels if needed.
The BBC found you need a still cabinet for bass, but a thin well-damped cabinet worked well for mids and HF.
I hope that you meant "stiff". Yes, for bass the enclosure needs to be stiff, but one can do stiff AND well damped at the same time.
Indeed. There are methods and materials that work extraordinarily well, but not all are practical or worth the cost. I love the way sand filled walls work, but have never built any of my speakers that way because, damn..... It's crazy heavy and rather labor intensive.
There are more clever way to get similar results, right?
cast iron with precipitated graphite flake, please - steel is usually very high Q
there are some AlMgZn die casting alloys that are "off the chart" high damping for metals
I think 2 outer constrained layers, one each side, for a 5 layer sandwich with thick center structural layer is more weight/volume efficient, do add the damping bracing too
Certainly - using a good knowledge of noise control techniques helps a lot.
Micarta?
How about Micarta (https://en.wikipedia.org/wiki/Micarta) for the baffle? I have access to 40mm Micarta in large enough pieces. Looks to me like a very good option.
Paxolin (sp)..... would be good if a thinner section was laminated to wood.
Interesting. I've never heard of Micarta, but have probably seen it.
FWIW, cargo shipping containers are now using a similar sort of stuff. It's woven bamboo matts that are pressed and soaked in some sort of glue and/or resin. Makes for a pretty floor. about 25mm thick. I'd love to find some to test for speaker building.
Remember the thin caramel colored plates we used to DIY circuit boards?
GM
- The best cabinet material !!!!
