ACA Mini "Almost Clone" Board
Is everyone comfortable with the bias procedure? If not I could do a quick video. It’s really quite easy though.
First, thanks again for doing all the legwork. There's about to be a flurry of amp building going on and you're responsible for it. !!!
I've not read the biasing instructions carefully yet ... that'll happen as the amp is built. But that sort of video, if it really doesn't take too much time to make, would likely be useful to a lot of folks going forward. There will likely be hundreds of these built in the next year or so and many will be newbies.
Joined 2011
Great video Kevin, congratulations!
Nervous builders may want to insulate the metal shaft of their screwdriver with blue painter's tape, all but the last 1 cm of the blade, so that any accidental touches between the screwdriver and the circuit, don't create a short. Or use an all-plastic screwdriver. Or perhaps a Bourns H-90 (sales link) purpose-made adjustment tool -- AFTER removing the metal clip that holds it in your shirt pocket.
None of this is strictly necessary, as Kevin's video proves conclusively. But if you want a little bit more peace of mind, why not?
_
Reactions: 1 user
