Posted 20th October 2015 at 07:49 AM byabraxalito Updated 26th October 2015 at 01:42 PM byabraxalito
Nowadays with discrete transistors as affordable as they are, the most cost-effective solution for a particular audio application may well be a discrete one when SQ (rather than numbers) is uppermost. Audiophile faddishness about discretes aside.
Here's a case in point - my pic shows a headphone buffer where the design aims were lowest cost, smallest size and lowest battery drain, while maintaining acceptable SQ. There are 28 transistors which go for 0.04rmb each on Taobao. That's 1.12rmb. OK so you can also buy 2 NJM4556s for that, but how do they sound? In my experience of building an O2-alike, not so great. They're also going to take 15mA at 7V whereas this design takes 6.5mA at 3.6V input. So an integrated design will be more than 4X as power hungry. With a 2600mAh single cell LiIon this could run for 400hrs - over two weeks continuous if played at low level.
The power supply is created by an LM2662 which inverts the 3.6V positive input for a -3.6V rail. It...
I have had the chance to listen to Q-cap Polyprop vs PIO. This is a very interesting pair of caps indeed. There is a difference. The Polyprops sound modern in a good sense, very good bottom and the upper freqs ar not extremely in the foreground. In an open sounding cirwquit, this makes sense. A very good capacitor, indeed.
But in my ears, the PIO are even a little better, little more open in a very very musical way, but not sharp. Wonderfull flowing and livelike, natural and dynamic.
The choice always depends on the rest of the chain and personal taste , But these are my favourites now.
It´s fun to listen with both of them and I´m really looking foreward to the time, when they are burned in...
Here's the power supply I've lashed up to feed the balanced SE classA amp.
Its fed from a 5VA EI transformer with a 65VAC secondary. One 390uF cap follows the rectifier, then there's a 30mH choke, two 390uF caps beyond that.
A series regulator is made from a string of 3 TL431s as reference (the max from a single one is 36V - I've gone for a total of 78V) and that's followed by a 2SK213 simply because I had no other high voltage transistor to hand. There's an RC filter feeding the gate of the MOSFET to reduce the output noise from the shunts (68k,200nF).
Output ripple isn't visible on my scope but I plan to feed the output into my AC millivoltmeter and see what its giving out in terms of noise.
One thing I hear from objective audiophiles is that amps should strive to be as neutral as possible because you should only hear what the record producer intended for you to hear.
Philosophically I do agree that I should hear what the artist meant for me to hear. However how do you know that the album was recorded while listening to a similarly neutral amp? Recording to a master tape usually doesn't include the amp powering the monitors so whatever they heard through their amp and speakers isn't captured on the tape. In order to really hear what was in the studio, you would need the same amp and the same set to speakers to listen to what they listened to. So if my home setup has a miracle amp and speaker that truly is ruler flat from 1hz-1MHz and 0.00001% THD, I probably still am hearing things differently then the artist because they probably used an average monitor that has -10db at 30Hz.
So how important is it really that an amp be neutral?
We will be hosting a house concert and recording session on November 20th, 2015, featuring the remarkable young artist John Statz. 8:30 pm music start, come earlier for food and drink.
Posted 10th October 2015 at 01:55 AM byabraxalito Updated 16th October 2015 at 05:36 AM byabraxalito
Headphone amps aren't any different from speaker amps in principle - what you hear (apart from a bigger version of the input signal) is the power supply's noise coupled through the inadequate PSRR of the electronics.
SE classA operation is a way to minimize the generation of power supply noise by arranging the current flow to be constant to a first order so that any remaining ripple on the supply is the result of the finite output impedance of the follower's loading current source and those of the driving stages. But how significant are these 2nd order effects? This design is an attempt to find out - by reducing them as far as practicable.
The idea is to run SE classA at a much higher voltage than is needed to drive the 'phones (balanced, with 80V supplies giving 144V peak-peak) then step down the output voltage with a custom-wound output transformer. This has the effect of increasing the PSRR of the amp's output stage. I'm not worried overmuch about the PSRR...
I admit I did not give ASUS the benefit of the doubt and seriously consider their Essence STX soundcard as a replacement for my Onkyo SE200-PCI. ASUS make nice motherboards, but unlike Onkyo have no previous expertise in high end audio.
I am happy to report - a bit late in the game, the card came out in 2009 - that they've done a really good job with it and the drivers for Windows 10, technically still in beta, work just fine.
Asus updated the design recently to the STX II. The PCB has been redone, but the only visible change is the PCM1792A DAC has been moved towards the top of the card closer to the IV conversion op amps. An second LDO regulator IC, U34, empty on the STX, is now populated. A "TXCO" clock source is added next to the ASUS audio controller IC. The four film caps next to the output IC are replaced with WIMA brand. It's basically identical, so it...
Current version is 5.60C, last update was 2012 to be compatible with Windows 8. Driver package 5.60C installs without issues on Windows 10 64 bit. The AudioDeck utility installs as well.
However, all is not well:
On installation, Immezio 3D effects are enabled. This locks the sample rate at 48 kHz. 44, 96, and 192 kHz cannot be selected. Deselecting the Immezio 3D effects prompts a reboot, but the Immezio 3D effects remain enabled after rebooting. The card is stuck at 48 kHz. 3D effects (which enables the DSP processing such as Qsounds, EAX, A3D) cannot be shut off.
I see three possible workarounds:
1. Find a command line switch, or edit the installation batch file to disable Immezio 3D on installation...
Posted 2nd October 2015 at 05:07 AM byrjm (RJM Audio Blog)
Updated 9th November 2015 at 02:44 AM byrjm
This is a headphone amplifier with digital inputs, not a DAC with a headphone jack. Though technically given equal board space, the headphone amp, with hot-running single-ended class-A output stage, is surely the centerpiece of the design. (The Asahi Kasei DAC, with MUSES01 for the I-V, is no slouch mind you.)
First impressions. It is large, solid, and very nicely made, but - after seeing the inside - rather simple, spartan even. From the DAC output to the headphone jack is just two op amps and two transistors, the op amps being shared between channels. A third op amp most likely just buffers the analog line output. Apart from the headliner MUSES01 op amp none of the parts are especially expensive, though many were clearly carefully chosen for sound quality - the 2SC5196 for example. The TE7022 USB receiver is a disappointment, as is, to be honest, the single set of power rails and the use of dual op amps shared between channels.
