Open Baffle Bass Boost: +4 to +7dB w/ Passive Xover, No DSP
I’ve always wondered if you use subs with these OB designs, especially Bitches Brew. I think you may be right about wasted energy, especially after the 12db/oct loss and increased excursion. But for film or dance music, it can be quite noticeable, having deep subsonic tones.
I've been enjoying my open baffle stand mounts for awhile now. I live in an apartment, so my neighbours appreciate the dipole cancelation laterally and vertically.
I highpass my power amp with a single cap per channel, and use an H frame sub for bass with great pitch but without the ground penetrating sonics when I used the same drivers in a ported enclosure.
Reactions: Jazzfan and D1sco
That's an incredibly compelling reason to go OB, @MITsound. I know the rule changes for rear wall distance depending on the person you're asking, their experience, the weather, magnetism, what their turbo encabulator says, but what do you do? My boxes live 2ft from the rear and that's only if I measure directly from the port angle directly to the backsplash. There's not a ton of wiggle room besides the 18" of box length to remove.
Very, very exciting thread!
Nowadays achieved a listenable OB, actually a SLOB, with a "full range" and a complementer woofer. The woofer has got a 3rd order lowpass filter somewhere around 200Hz.
My question is whether changing the filter to a 2nd order lowpass, a similar "boost" effect could be achieveable? Lowering the x point could also be an option to taylor the graph. (the woofer is a field coil one, with adjustable parameters)
One can achieve a boost at the crossover point using a third order lowpass filter as well. Do you know the component values of the current low pass filter?
Perrymarshall,
Boost at around 200Hz would not be beneficial indeed, but I wrote I can decrease the X-over point to 80-100Hz and adjust the fullrange accordingly.
But this X-over point is not a real X-over point, since the fullrange doesn't have an electronic highpass filter.
Mboxler,
L1: 10mH, C:220uF, L2:3,3mH, well, its rather a 150Hz LP, not 200Hz. (Re: 6,3Ohm) And yes, there is a hump at around 150Hz in the frequency response, but not that high.
I simulated a third order low pass that ultimately ends up with an equal slope. It consists of 5mh, 300uf, 5mh (BLUE).
The price you pay is that you end up with an impedance dip below 2 ohms ((RED).
@jimk04 below 0.5 is problematic. 0.5 means driver in an infinite baffle is down -6dB at resonance. Lower than that means it's down even more. 0.36 = -8.9dB and the LC circuit boost can't overcome that. The LC circuit can add about 4-7dB boost, sometimes a bit more.
Low Q drivers are just fine if you have active / DSP and in fact I prefer them. (You also need to add subsonic protection.)
But for passive you need higher Q drivers, and the passive bass boost circuit helps a great deal.
the bass peak, or boost, happens when impedance in series with the driver at driver main resonance frequency is increased so that electrical damping is reduced. Now the driver does not EQ itself anymore (through backEMF) and system Q goes up. It works for any Qts driver, but perhaps this particular application on this thread requires some particular Q. Still, the "boost" is there available for any Qts and exploitable in any system if necessary, although perhaps not very practical if Qts is already past 1.
One can test this directly in VituixCAD enclosure tool for closed boxes, select a driver and toggle the series cap on the filter tab. It should work similarly with OB as it is function of the electrical damping and adjusted/exploited per project, if it's something useful.
On these images the overlay trace in SPL window is "auto aligned" closed box response for each driver, and the black line shows response with 470uf series cap added. One can tailor the Q with box size and cap size. These are some random drivers with few different Qts to demonstrate, nothing special.
The trick increases excursion which increases distortion for the whole bandwidth so it's not free lunch. Excursion and thus distortion would rise with DSP as well so in that sense it's nice, bass boost without DSP.
Reactions: perrymarshall
Edit time over, gotta add few more observations from the closed box examples:
  • the boost on the above examples is mostly below the impedance peak frequency
  • Also, as the cap increases high pass slope, which partly reduces excursion on the very lows, so perhaps distortion penalty isn't as bad as it could.
  • peculiar thing with also a resistor added, straightens the response (reducing current on mids than at the resonance), and while the cap doesn't add that much boost anymore it still does some contouring of the Q, but not a boost anymore. Also distortion would be reduced some (hint of current drive).
ps. it's simulated response and impedance of the Beyma 15p80, from example above.
Someone who is building an active DSP system asked me about including the Passive Bass Boost in his design.
I replied:
When you are doing an active DSP system there is no reason to use the Passive Bass Boost. That is only for 100% passive systems. (Actually you should post this question on the group forum because other people need to know this):
-The large inductors will have hysteresis distortion, and the capacitors have Equivalent Series Resistance
-The Passive Bass Boost only gives a very limited amount of boost and it will only work within a certain range of frequencies just above resonance for any woofer
-DSP is far more powerful, and gives you the ability to shape the response however you want.
So you should put as few passive components in your system as possible. Like capacitors to protect the tweeters from DC for example.
I do think you should roll off the DSP below the cutoff frequency of the system so you don't overload your woofers.
