That should be the function of a charger. Passive battery management board need to be compatible with different kind of chemicals, as well as different voltage.
Ian
yeah Ian IMO that should really be a function of the battery management board, since the charger is not connected when under load it is not there to monitor the battery charge. there are not many different voltages, the vast majority will use LiFePO4, initially I had presumed you were using a combination of latching/non-latching relays and resistors to passively set the cut off voltages, only when I went to order the parts and take a closer look at the schematic did I notice it wasnt included. without something to do this, it will be very easy to damage and in some cases risk unstable chemical reactions.
this is IMO more important than catering for inrush current in other applications
actually i'll modify that, its more important to me for my objectives, you have your prerogatives.
Lets first clarify the situation that you're concerned about. The battery management board in its current design assumes that the device will be turned off while the batteries are not fully discharged. What about when someone walks away without turning it off and the batteries are allowed to continue to drain for an unknown period of time.
Is that the situation that you're concerned about?
I don't see a reliable way to sense voltage and trigger the relay for shut down without active devices. An under voltage threshold set by comparator and a logic gate would be what I'd add off board but it would no longer be passive...
As an aside, could we run a dropper resistor and led, giving visual confirmation of suitable voltage, run an LDR after the led to keep the "active" devices to of the loop. Or will the noise of the led's be adding noise to the power supply, though at dc it will be a constant current? If we then monitor the LDR resistance to switch off ad charge, is this not a wimpish way to do it? Not the most accurate for sure, but a simplistic method?
Just a thought.
Just a thought.
I'm interested in your solution, any details?
Ian
Just a thought.
The LDR being a separate device of course but in series using the same current as the visual led.
You can probably tell I'm not an electronics genius.....
That's good idea. An optical isolator may can do the same job as the led and ldr.
This question is connected to battery protection issue. Actually any lithium battery has a small protection board inside the battery pack. The protection board provides both over charge and over discharge protection by switching the MOSFET. However, my concern is any passive components will introduce noise ....
Ian
on the other hand it should be an easy enough mod to add, using one of te optional connectors to tap/sense the voltage
Current design already has a connector to monitor the battery, but how to make use of the monitoring result to cut off the relay without introducing
noise or short the ground is a question.
Ian
it will require working with the dual clock or fifo board signals I guess if you must have it disconnected at all times during audio. but i'll need to think some more on a more automatic plan. it will likely utilize a couple transistors, so not completely passive.
most lipo batteries with protection create more of a noise issue that any protection circuitry we might design, my A123 have nothing, any OEM bought cells usually wont either. A123 wont explode or catch fire when fully depleted, they just can get damaged, but some lipo may have pretty serious issues
I searched TI and couldn't find any battery charger IC has battery discharge protection![]()
I use linear tech LTC2935, not a charger, but a battery monitor.
WOW....
My heads spining
I just read 145 Pages !
But still see no mention for HDMI or multi-channel yet
Looks good though Ian
Ian
yes but thats hardly a universal solution is it? the TPA is good no doubt, but its bettered by many discrete designs, or plain batteries; I would likely be using batteries to power clock directly
There is a battery monitoring connector on the PCB, maybe your can make use of it for now.
But to solve the battery protection problem completely, we need a active battery management board with two groups hot swapble battery and charger working all the time. If the working battery is found to be low, it will be replaced with the other one without stop the music.
Ian
Fifo: sujects follow up
After re-reading this thread from the begining up to page 100 I think it would be nice to review some topics already dicussed many months ago here:
1- Ian what is new the total current requirement for SPDIF+DUALCLOCK+FIFO+BAT boards?
2- I want tu use 2 x A123 LiFePO4 battery to power my kit. Voltage is really near the max limit of 6.7V stated in the fifo doc. I expect about 2 to 3 hours of operation for a 400ma consommation.
qups still using your LiFePO4 setup with succes?
3- I have 2 SI570 HAM modules and also purchase upon Ian recommandation the CCHD-957.
Anyone tried the AccuSilcone module mentioned before in this thread?
4- Somes exchanges were about the fifo delay problem for a audio\video setup.
I think the main point was missed, Even for a audiophile setup the first thing to do is simply a disable fifo buffer option. No need to implement some complex algorith. The avantage of using the same HIFI stereo system for both video and audio is a great one even if the video part don't have the jitter reduction feature.
For example I'm using a nice HDMI switch with a SPDIF output so all my audio\video sources can output to my HIFI stereo setup
WOW....
My heads spining
HDMI? not going to happen, licensing rules it out for hobbiest projects.
multichannel? welcome to the line of people poking Ian with a stick
- Digital Line Level
- Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
