If it's a VDMOS device, you should probably use the VDMOS model. I don't know if there are any models available for those.
LTspiceXVII model for IRF730 n-Channel Power MOSFET
Hi Everyone,
Does anyone have an LTspice model for an IRF730 n-Channel Power MOSFET?
Even a model of something close would do as maybe I can change a few parameters to match the datasheet for an IRF730. A quick search of this thread didn't show me anything. Thanks a lot for all your help!
Cartman222
Hi Everyone,
Cartman222
Thank you euro21 for your quick and helpful reply!
I just had a bunch of those old IRF730 parts sitting around and wanted to experiment with them.
HI, how do you check your spice model ?
I would like check that : (from MicroCap9)
thanks
Code:
.MODEL 2SJ79 PMOS (CBD=166.075P CGDO=1.65276N CGSO=1.65276N GAMMA=0 GDSNOI=0
+ IS=10F JS=10N KP=20U L=2U LAMBDA=24.1203M NLEV=0 NSUB=0 PHI=600M RD=1.88227
+ RDS=1MEG RG=10 TOX=0 TPG=1 UO=600 VTO=322.944M W=3.50594M)
Code:
.MODEL 2SK216 NMOS (CBD=157.257P CGDO=1.65276N CGSO=1.65276N GAMMA=0 GDSNOI=0
+ IS=10F JS=10N KP=20U L=2U LAMBDA=1.73074M NLEV=0 NSUB=0 PHI=600M RD=118.643
+ RDS=1MEG RG=10 TOX=0 TPG=1 UO=600 VTO=-41.5076M W=11.0669M)
thanks
.model IRF730 vdmos VTO=3.826 RS=0.02372 KP=2.754 RD=0.7175 RG=5 mfg=International_Rectifier Vds=400 CGDMAX=2.50n CGDMIN=5.00p Cjo=1.44E-10 IS=5.14e-13 Rb=0.0198 TT=1.225e-06 Cgs=6.23E-10 Ksubthres=0.1
Code:.MODEL 2SJ79 PMOS (CBD=166.075P CGDO=1.65276N CGSO=1.65276N GAMMA=0 GDSNOI=0 + IS=10F JS=10N KP=20U L=2U LAMBDA=24.1203M NLEV=0 NSUB=0 PHI=600M RD=1.88227 + RDS=1MEG RG=10 TOX=0 TPG=1 UO=600 VTO=322.944M W=3.50594M)
Code:.MODEL 2SK216 NMOS (CBD=157.257P CGDO=1.65276N CGSO=1.65276N GAMMA=0 GDSNOI=0 + IS=10F JS=10N KP=20U L=2U LAMBDA=1.73074M NLEV=0 NSUB=0 PHI=600M RD=118.643 + RDS=1MEG RG=10 TOX=0 TPG=1 UO=600 VTO=-41.5076M W=11.0669M)
thanks
The NMOS and PMOS refer to the method used to model the transistor. NMOS and PMOS are generally not suited for discrete MOSFETs (at least those we want to use for audio), but it is what was available at the time most MOSFET SPICE libraries were created. I wouldn't trust the device capacitances, low current behavior or crossover behavior to be correct. Generally you want to look for VDMOS models which incorporate the subthres or ksubthres parameter. If the parameter isn't present you can add ksubthres=0.1, which will not necessarily make it more accurate, but less buggy.
Thank you for your answer, meanwhile I switched to IRF9610 and IRF610, but again it is necessary that I find models, so it's better using VDMOS or SUBCKT and i also have Nmos and Pmos 🙁
.SUBCKT IRF730 1 2 3
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
* by Symmetry License Agreement *
* Model generated on Sep 8, 97
* MODEL FORMAT: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
* Default values used in MM:
* The voltage-dependent capacitances are
* not included. Other default values are:
* RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
.MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=4.08133 LAMBDA=0.00196769 KP=3.10024
+CGSO=6.36039e-06 CGDO=1e-11
RS 8 3 0.0677475
D1 3 1 MD
.MODEL MD D IS=6.91304e-09 RS=0.0167032 N=1.5 BV=400
+IBV=0.0001 EG=1.2 XTI=2.71224 TT=0
+CJO=6.68134e-10 VJ=3.03288 M=0.851335 FC=0.5
RDS 3 1 2e+07
RD 9 1 0.731541
RG 2 7 4.31009
D2 4 5 MD1
* Default values used in MD1:
* RS=0 EG=1.11 XTI=3.0 TT=0
* BV=infinite IBV=1mA
.MODEL MD1 D IS=1e-32 N=50
+CJO=1.03652e-09 VJ=1.39088 M=0.9 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
* EG=1.11 XTI=3.0 TT=0 CJO=0
.MODEL MD2 D IS=1e-10 N=0.535061 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 1.03652e-09
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
* RS=0 BV=infinite IBV=1mA
.MODEL MD3 D IS=1e-10 N=0.535061
.ENDS irf730
Hi UltimateX86, See attached.
thank you very much Ian, thank you also for the Exicon that I use a lot right now
IRF710 VDMOS model, updated IRF610 IRF9610
IRF710 below.
NB: My earlier IRF610/9610 model has been updated: Rd, Ron, Qg corrected.
Saturation region parameters were OK. The earlier models still work OK just better now when clipping. They are still not perfect but quite useable.
*VDMOS with subthreshold (c) Ian Hegglun Apr 2019
.model IRF610 VDMOS (Rg=5 Vto={4.30-6m*(0+temp-25)} Lambda=3m
+ Rs={35m*(1+3.5m*(0+temp-25))} Kp={0.5/(1+8.8m*(0+temp-25))}
+ Ksubthres={0.23*(1+4m*(0+temp-25))} Mtriode={0.35} Rd={1*(1+5m*(0+temp-25))}
+ Cgdmax=260p Cgdmin=10p a=0.35 Cgs=125p Cjo=300p Tnom=temp
+ m=0.75 VJ=5 IS=1n N=1.3 Rb=0.01 Vds=200 Ron=1.5 Qg=8nC mfg=IH201904 )
.model IRF9610_ VDMOS (pchan Rg=6 Vto={(-3.76+2.5m*(0+temp-25))} Lambda=4m
+ Rs={68m*(1+3m*(0+temp-25))} Tnom={temp} Kp={0.35/(1+3m*(0+temp-25))}
+ Ksubthres={0.2*(1+4m*(0+temp-25))} Mtriode={0.5} Rd={2*(1+9m*(0+temp-25))}
+ Cgdmax=120p Cgdmin=15p a=0.26 Cgs=113p Cjo=207p Tnom=temp
+ m=0.75 VJ=2.5 IS=1p N=1.5 Rb=0.02 Vds=-200 Ron=3 Qg=11nC mfg=IH201904 )
.model IRF710 VDMOS (Rg=5 Vto={4.40-6m*(0+temp-25)} Lambda=3m
+ Ksubthres={0.23*(1+4m*(0+temp-25))} Mtriode={0.2} Rd={3*(1+5m*(0+temp-25))}
+ Cgdmax=260p Cgdmin=10p a=0.35 Cgs=150p Cjo=300p Tnom=temp
+ m=0.75 VJ=5 IS=1n N=1.3 Rb=0.1 Vds=400 Ron=3.6 Qg=17nC mfg=IH201904 )
The attached jig is useful for plotting Id/Vgs and Id/Vds by only changing one command line (nice). Presently compares IRF710 to IRF610. You can compare one being fitted to another to see what's changing (nice). You can compare n- with a p- by editing the 'pchan' to 'nchan' and reversing the Vto sign (don't forget to undo these when done). Enable the .Temp 25 150 for temp stepping.
BTW with the jig you can see the IRF710 is almost the same as the IRF610 except for higher Rd and diode series Rb. Mtriode changes when Rd changes - you choose Mtriode using the Id vs Vds, to fit the ending Vds for the triode region.
BTW2 the "(0+temp-25)" You can add "50" in place of the "0" in all instances and you can set the junction temperature of this power MOSFET 50 deg C more than the ambient set by .Temp X (27C if not set).
I now prefer to set the junction temperature of my power MOSFET's by adding a Temp=X after the part name ('Value for M1'), eg, "IRF710 Temp=Tjp"
Then I add line .param Tjp=27
then add
.Step param Tjp List 27 77
This shows changes at start and after warmup with a Tj rise above ambient of 50C for the designated transistors.
BTW3 The above is useful for checking bias stability. You can do the same with bias diodes eg, "1N4148 Temp=Tjd" and define Tjd on a heatsink, eg,
.param Tjd=27+0.7*(Tjp-27)
where the "0.7" is the fractional drop from the power transistor junction to the heatsink sensing point, the ratio Rj-hs/Rj-a.
Hi All,@Ian,
Do you have a VDMOS model for IRF710, thank you?
IRF710 below.
then add
Excellent work Ian, very useful setup, thank you!
It would be very nice indeed if you could the same for IRFP9140 (for less then +/-40VDC supply) and IRFP340 (for less then +/-80VDC supply) as these are way more complementary devices than IRFP240 for IRFP9240...and yes, I do sound like a huntin dog chasing you...sorry!
Hi aparatusonitus,
I'll have a look next few days. BTW have you read my white paper explaining VDMOS parameter fitting? VDMOS - PAK2 devo
I'm embarrassed...I missed all the articles in your signature, unbelievable...the good thing is I have a lot to read, understand and implement, thank you!
Hi aparatusonitus,
If you are interested in symmetry, did you see my recent Echo amp circuit?
Spice model for Russian KP903A JFET?
I thought of it for LU1014D's. But now propose 5th generation trench MOSFET's. Most are aware generations after the IRF640 generation can't be used in linear mode direct off the +/-40-80V rails due to thermal hot spots (Spirito effect). But using them as Rush pairs with RET power transistors you get true symmetry and a wider better crossover region. Still just simulations.I have written a paper explaining the options for making a practical 50W or 100W using this arrangement. It is here IansEchoAmp - Google Drive
Interesting ... but I would rather spend time and money on Sony/Yamaha/NEC V-fet (SIT) because I have a fair amount of each (I even have the "non-existent" and unobtainable Yamaha 2SJ27 but not a single one 2SK77🙁
- Design & Build
- Software Tools
- Better power MOSFET models in LTSpice
