Lynn Olson said:I would like to point everyone to what's going on over at Magnetar's thread.
Things have taken a very interesting turn, discussing both the B&C 6PEV13 and the 18Sound 6ND410 in a 300 Hz horn, paired with a 5X 10" woofer dipole array.
By getting the horn out of the way around 3 kHz, that sidesteps a lot of the typical "horn sound" when a horn is asked to cover the range from 1.5 to 15 kHz, as well as a lot of phase-plug troubles (non-uniform wavefront entering the horn) when compression drivers are used. Another appealing feature is the effective radiating area of the horn is similar to the radiating area of the open-baffle drivers - I can see using the 300 Hz horn with a 4X array of 12" drivers, for example.
Hmm - a quad array of mix-n-match Alnico+ceramic 12" Tone Tubby's, a 300 Hz horn with the 6ND410, and a double-high RAAL tweeter (which delivers an additional 2.5 dB at distances greater than 2 meters). Let's see now, no bi-amping required, efficiency somewhere around 103 dB/metre, a pretty simple 3-way system, hmmm .......
Lynn,
I am trying to work with what I already have as far as drivers and horns. If it was from scratch I think 4 mid QTS 12's would be fine. I believe you should not use a typical prosound .2 - .4 driver down there, maybe .45 with a little eq - If you go over .8 it can still sound good (no eq) but gets 'woolly' sounding . For example the Eminence Alpha 15 - I see a lot of folks are using them open and my experience with it and the big 21" Madison ultra high QTS driver is they sound a bit slow and detached when used with a high quality mid and treble. The smaller .7 QTS drivers are a world better. I haven't looked but there are probably a few different HE upper QTS mid xmax tens or twelves out there. Try bass guitar speakers..! Look for woofers that don't get nasty above 1K, low pass them with a 4th order electronic crossover. You can still use a passive line level xover to the mid - Run simulations on the quartet and look at the excursion and power handling at 45-60 (probably your lower limit) cycles in a large (like 200 cubic foot) infinite baffle to get an idea what they will do on the open baffle when mounted low 'in room' - also remeber I high pass my bass..
For the mid the 18 sound driver should be awesome. I would however use a 250 flare horn. Any smaller and you probably want to cross over lower ( I do) and can't and any larger you will get beam and honk. The horn will 'break the rules' and will be shorter than what most horny's will recommend , that's OK - this is a mid horn - it will sound better.
Personally I like the treble to match the mid. Here I use the cheapo Dayton 1.8K conical round horn with 70 degree dispersion. The ribbon will be OK , I have tried to match a ribbon with a mid horn in the past and feel the higher you cross the better chance of success you will have. 8K or higher is probably best. I can't imagine finding a cone mid horn that will be usable beyond 3-4 k though.
Re: 12''
I think something more on the lines of .5 to .8 QTS and 98 db/w sensitivity - He is looking for high efficiency bass drivers not sub drivers, something with a net array sensitivity of 103 db or so at 50 hz mounted on a board
Maybe six of these - http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-332
The top end is kinda funky though
SunRa said:I think the Tone Tubby alnico would be the perfect candidate for the bass array. High spl, qts of 0.8, and hemp.
edit: although I couldn't find anything about the xmax..
They are 279 each! thats $ 2000 for the bass! Too much money (for me at least) - plus no response graph - bet they scream above 1k - that's what bass guitarists crave!
Re: Re: 12''
As long as you realize that they're not anywhere near 98dB in the relevant bandwidth, they look pretty okay.
Why can't we just go to a 3 point sensitivity spec for woofers, 50Hz, 100Hz, and 1kHz, infinite baffle anechoic measure, it'd sure help designers have valid info to compare.
What about four of these per channel with a little EQ for a lower cost multi-amped OB?
http://www.partsexpress.com/pdf/290-516s.pdf
Actualy Mr. Lynn Olson measured and auditioned them and he was quite impressed. I saw the graph on his web-site... no usual guitar break-up there...
Re: Re: Re: 12''
6 of them are in series parallel at 60 cycles is 98 db, in parallel (use 16 ohm woofers like i do and you are over 104 without room gain. Here are 6 of these in parallel (110 db/w - 104 at 60 cycles) - too low of an impedance!
This is one example that won't break the bank, not what I'd use
It's kind of BIG = LOL
Norris Wilson said:What about four of these per channel with a little EQ for a lower cost multi-amped OB?
Four of those will do 120 db at 50 cycles before destruction- 95 db at 60 cycles without eq or room gain and be 102 db sensitive at 400 cycles - they'll need eq, good bass power is cheap
Four of these are better for this and cheaper
http://www.partsexpress.com/pdf/264-334.pdf
97 db at 50 cycles, 99 at 60, and 101 at 400 - less eq required
On sale for 40 bucks a piece..
SALE
Hi
Just came across this page,
Reproduktory 5" + 6" + 8"
http://www.prodance.cz/protokoly.php?AnchorID=49&Lng=CZ
Reproduktory 10"
http://www.prodance.cz/protokoly.php?AnchorID=50&Lng=CZ
Reproduktory 12"
http://www.prodance.cz/protokoly.php?AnchorID=51&Lng=CZ
Reproduktory 15"
http://www.prodance.cz/protokoly.php?AnchorID=52&Lng=CZ
Reproduktory 18"
http://www.prodance.cz/protokoly.php?AnchorID=53&Lng=CZ
Reproduktory 21"
http://www.prodance.cz/protokoly.php?AnchorID=54&Lng=CZ
Reproduktory 24"
http://www.prodance.cz/protokoly.php?AnchorID=55&Lng=CZ
Some have MLSSA CSD – disillusion guaranteed....
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Greetings
Michael
Lynn Olson said:Mo' data mo' bettah.
Reproduktory 10"
Reproduktory 12"
Reproduktory 15"
Reproduktory 18"
Reproduktory 21"
Reproduktory 24"
Greetings
Michael
Goldwood 10's
6 of these in series- parallel will be 100 db at 60 cycles
Look for a similar 10 (maybe a little lower fs and qts) at 16 ohm and run 5 or 6 in parallel - that's what works for me
Hi
Hard to believe that the prominent 2 kHz peak does not resonate.
Greetings
Michael
Greetings
Michael
Just found that bass driver. 15", but look at the Mms:
http://www.olimpiaudio.com/Prodotti/Cleveland/W416Neo.html
It's very light cone for a 15'' river... From the same producer, a 10" with a mms of 25 g and 98dB sensitivity: here
edit: the ferite 15" version is having a higher Qts.. (around 0.5), with the same cones which makes them well suited for OB. Especially this one looks very nice though: 37grams Mms, 101db sensitivity, 0.36Qts.
re
Very nice website. Good measurements! Some of the smaller B&C look very well behaved, the RFC too. Thanks!!!
mige0 said:Hi
Reproduktory 10"
Reproduktory 12"
Reproduktory 15"
Reproduktory 18"
Reproduktory 21"
Reproduktory 24"
Greetings
Michael
Hi
http://www.olimpiaudio.com/Prodotti/ATD/2140M.html
Look at the price – isn't it olympic !?!
Greetings
Michael
Greetings
Michael
Hi
Olympic !?!
Not at all - I think I am in a dream !
http://www.olimpiaudio.com/Listini/ListinoFostex.html
Greetings
Michael
Olympic !?!
Greetings
Michael
SALE
Magnetar said:Goldwood 10's
I tested members from both of these product lines, here: http://s139.photobucket.com/albums/q288/augerpro/Selenium 10PW3/
http://s139.photobucket.com/albums/q288/augerpro/Goldwood GW-1258/
Neither has impressive distortion at bass frequencies, and the Selenium has pretty high odd order in the midbass/lower midrange.
- Beyond the Ariel
