OK, I will hopefully get the R-core transformers somethime this coming week and will be able to power everything up. I'll let you know what the results are.
Greg
Sounds Great Thanks!
Tom
Oh, no one has given a reply. I need to reply.In RMAA FFT size set to 'default' and optimizatios to 'px'
EMU under test ofcourse set to 48/16.
Marek, please accept my comment as just a private one from an inexperienced non-professional digital audiophile.
I'm afraid that your measurement instruments and conditions are too handy to be accepted in this industry or community.
I think you know very well that 16 bits is comparable to 96dB. Many people may think the precision is not enough.
I understood that you connected ES9018 raw outputs to EMU high impedance input without any amplifier or conditioner except 1:1 transformers. People in this thread know ES9018 favors a low impedance node.
I hope you understand what I want to say well.
Hi Bumpei, wouldn't the DAC pad to 32bits?
Yesterday I made a measurment using LL1931 (1:16 config) trafo as passive output strage loaded with 3k Ohm resistor on secondaries. Effective load connected to diff DAC outputs is about 10ohm (DCRs taken into account) so I think I can tell that every diff output is loaded with 5ohm.
With this small (but not zero) load DAC works near "current mode".
Ofcourse testing conditions the same as pervious.
As you can see 3rd harmonic is -120dB, 2nd harmonic shows up with -111dB level which is pretty acceptable (2nd harmonic is inaudible even with quite high levels)
So the conclusion is that pervious -90dB 3rd harmonic isn't regarded to limited 16-bit resolution, nor EMU performance but it is clearly regarded to voltage mode (with high voltage swing). Everything OK but I don't get it why datasheet claim -108dB..
You haven't tried the datasheet setup yet. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But your observation is natural, using the Sabre chip in voltage mode is not ever going to make it shine.
The closer to zero ohms at the chip analog outputs the better the measurement will be.
2nd order distortion is not inaudible, it is simply not usually considered offensive, but yes -111db is not bad at all.
You need to make the distinction that you are really measuring the ES9018 not in just in voltage mode. You measured it direct output mode, with no output stage at all.
There is a distinction. I think if you connected the thing up to a balanced to single anded converter like the Ballsie Lite, or even an IVY-III setup for voltage input, both of which would be voltage mode, you would get better results.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Even if BufII in voltage mode measure worse than EMU stuff it still sounds way better - its certainly another league. Human ear it is weird sensor which perceive sound waves in other way than meters and is more sensitive to effects that we cannot measure..
I've been happy with the sound of the BuffII in "naked voltage mode"
I am not sure yet why the sale has not been activated, I am trying to contact Brian and see what might be going on. I apologize for the delay.
I do know that none have been sold yet(at least that I know of) so we will likely just have to move the sale back a day or so.
I will update you as soon as I know anything.
Ok, thanks Russ. Please move it up a day. I would hate to miss out this time just because I'm not staring at the computer until its fixed
All the best to your family.
Thanks. Everyone is fine.
- More Vendors...
- Twisted Pear
- Buffalo II
