Hi matthiasw,
This USB to Toslink converter is only intended for use with the PowerDACs that contain a S/PDIF DAPI receiver that offers a very high degree of source immunity as we tackled both, the source noise problem -and- the jitter problem inside the PowerDAC.
It's not based on the XMOS, we use a small 28 pin ARM processor + custom software.
You can find information about the planned PowerDACs & versions here:
- ECdesigns
Is this device also XMOS based like U192?
Will you release a "non-PowerDAC" with DAPI similar to your existing FractalDAC?
- ECdesigns
You can find information about the planned PowerDACs & versions here:- ECdesigns
Thank you
Would it be possible to post some pictures of the PowerDAC-S as well?
Thanks again
Matt
If it's feasible within the way the DAPI buffer works, it would be neat if it could be set for a variable amount of delay, to time align two drivers using 2 Power DACs. Each power DAC may still drive a passive filter, but something like a first-order LX-mini could be feasible, where the FR sits centered above the woofer
I guess a spidf FIFO buffer with variable delay ahead of one Power Dac would work as well, just curious if DAPI could accomplish it
Thanks for the website update!
Back to the TDA1541A....
Going balanced was THE most impressive improvement in SQ. Doing that by using the Chinese CPLD board from AliX.
Also replaced the originally used TPA6120 headphone amp by an IN1620 evaluation board, keeping the OPA1656 I/V. Also replaced the PCM2706 USB to SAA7220 by JLsounds USB and Foobar SOX resampling.
All DC-coupled, with no offset problems whatsoever. The balanced to single ended with the INA1620 does magic.
Just to repeat the old story, there is something regarding voices and timing, the TDA1541A does so special, nothing else comes close.
I'd like to listen to the TDA1541A S1 or late South Asia with nowadays ECDESIGNS digital front end. I'm sure it will be great... the digital front end is often 50% if not more of the sound that the dac chip gives you. Add 30% for the analog I/V stage. The 20% of the Dac chip stays of a great importance... and here those 20% of the TDA1541A have not really or many better swap since ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But at the end all is about also about the whole layout.
I can get my hands on a series of TDA1541A S1 versions. Genuine new old stock from a repair company in Belgium so no Chinese fakes.
I would want a few for myself but am able to buy the whole stack of about 15 pieces.
Would there be interest from you guys in these chips?
Naturally it depends upon the price
I AM all in for stacking the stock.
Or better, I AM willing to swap awful and depreciating Fiat currency for valuable goods.
I seem to remember dear -EC- will spoil us with some genius circuit for it, at some point.
![wave :wave: :wave:](https://files.diyaudio.com/forums/images/smilies/wave.gif)
M.
+ 1Hi,
is it with one or two crown ?
And what price is ?
- Digital Line Level
- Building the ultimate NOS DAC using TDA1541A
