MPP
Andreas, that is plainly true.
About the time I bought the SME 3009 SIII* that I ended up never using to try on high compliance cartridges I had an audio technica AT-34 bayonet mount. Given it's compliance and the weight of AT arms fo the time that was about 6.7Hz. Clearly AT were not worried about low resonant freqency. I kinda wish I hadn't sold that cartridge as it really did perform well.
*5.5g with the standard wand.
With a resonance of 6.7Hz, I'd employ a Sallen-Key filter (thanks to Rod Elliot) to the RIAA preamp outputs to eliminate anything below 18-20Hz.
I've installed them on my various TT setups with excellent results.
No more airborne feedback issues at high volume, no rumble worries, and you don't even miss the woofer-pumping of a warped record, it's gone.
With those issues solved, the amp's power can concentrate on the music.
Project 99 - Infrasonic Filter
