I use the HF146 (without R) and it does very well IMO-- also at its upper end. But I must also say that my hearing starts to drop between 12 and 14 kHz. The diaphragm of these drivers isn't that large at all. It is around 2.5" which is a good compromise for a driver that can be crossed quite low at domestic listening levels and used in a two-way system.
Charles
Charles
Hi Legis,
I've been following this thread from the start and I must say this project is a beast!
I would like to get your opinion on mating the HF1440 with this 18sound 15NTLW3500 in a 2-way, will be using Hypex Fusion. also, what horn would you recommend?
Eighteen Sound - Professional loudspeakers
Thanks,
Anton
Thanks,
Anton
As do the Faital's. Fair enough, though I'd like to be able to do a sound quality comparison.
Stupid thing I did once was to misconnect a DSP .. switched the HI/LO on a 2-way on one channel. Faital 15" and a AMT. Wasn't till I was listening to a particular track that I caught it .. after an hour or so. That's how smooth the 15" is at half the price. What does the extra $250.00 get a guy?
It is difficult to say without having one to compare. I guess you used a 15pr400, right ?One advantage of the new 18s is its dual-gap motor. It was developed with the intention of being used over a large bandwidth. It has very low inductance, symmetric drive and also a demodulation ring.
Charles
Charles
phase_accurate ... yes, the 15PR400. I got a pair, new, for $400 a few years ago. I'm happy with them. They're in a 185l sealed box. I did model the 18Sound a couple days ago and it'll work in a med size BR enclosure, nice low frequency extension, looks like.
ErnieM .. for home HIFI I wonder just at what SPL this will be a factor. I'll sometimes listen at 100db (3 meters) and that's plenty for the wife downstairs
I've tested the Faital at this level and THD isn't an issue. I can see the advantage in a PRO audio setting but I doubt they'd ever get to "shine" around here. I'd love to be able to hear them in a 2-way app. though.
Charles,
nice to know I am not the only one thinking of a 2-way implementation.
Regards,
Anton
I've thought of the XT1464,it's getting positive feedback from diyers.
Thanks.
Ernie,
My mind was almost made up on the Faital 15PR400 then I saw you posted a link of the 15NTLW3500 in one of the threads...you're a bad man Ernie and also you, Legis![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Regards,
Anton
That is a combo that I was eyeballing as well and which I think could be very cool. But I was also wondering which horn to prefer.
Charles
Thanks.
I would go LTH142 or XT1464, yes, response is mystery, but atleast they are cheap non metallic horns.
Ernie,
More bass without sacrificing midrange clarity is the advantage.
Hi puppet,
How low does the 15PR400 go in the 185L sealed box?
Thanks.
Thanks.
ErnieM .. for home HIFI I wonder just at what SPL this will be a factor. I'll sometimes listen at 100db (3 meters) and that's plenty for the wife downstairsI've tested the Faital at this level and THD isn't an issue. I can see the advantage in a PRO audio setting but I doubt they'd ever get to "shine" around here. I'd love to be able to hear them in a 2-way app. though.
I am already using an XT1464 together with a Faital HF 146. Sound is nice and, apart from achievable level and dynamics, very non horn-like.
It is just the urge to try something new once in a while. The HF 1440 and the 15NTLW3550 are such beasts that draw one's attention to themselves.
Charles
Charles
Ernie,
My mind was almost made up on the Faital 15PR400 then I saw you posted a link of the 15NTLW3500 in one of the threads...you're a bad man Ernie and also you, Legis![]()
It really just comes down to spl requirements. The Faital is a good driver if you only need a couple millimeters of excursion for your enjoyment.
- "Shadow of The Colossus" build thread
