I have gone back to post2851 but can't find your required output voltage.
Could you remind us what the reg specification is?
Reg input 55VDC output 46VDC V1.0 RS
R1=22r is not 500mA.
What is R1?
the CCS dissipation is [Vin - Vr1 - Vout] * Iccs
I'll guess at some inputs:
Vin =61V
Vr1 =2V
Vout = 46V
Iccs =0.5A
Pq1 = 6.5W
Ta=25degC
It would take quite a few seconds even with a tiny heatsink to burn out the CCS FET. With an small but adequate sink say 10C/W the sink rise would be 65Cdegrees above ambient.
Tc ~ 70Cdegrees above ambient. That puts Tc ~95degC
The temperature de-rating for the FET is 0.44. [150 - 95] / [150-25]
Your 150W FET is de-rated to 66W
Pq1 ~ 10% of maximum rating.
If the FET is cold it is not passing current.
It has almost certainly not been damaged by over-voltage.
It may have been damaged by soldering or handling or simply the circuit has a fault.
What is R1?
Vin =61V
Vr1 =2V
Vout = 46V
Iccs =0.5A
Pq1 = 6.5W
Ta=25degC
have you connected the two 21Vac secondaries in series to get 56 to 61Vdc from the PSU?
yes
What is R1?
Vin =61V
Vr1 =2V
Vout = 46V
Iccs =0.5A
Pq1 = 6.5W
Ta=25degC
R1 is 3R8 to get 500mA
the current is ~0.5A
The dropping resistance is 150r
How hot does it get?
Have you done the arithmetic?
P=I*I*R=37.5W
Why use 10W resistor?
Why use 150r?
It's very very hot can left the finger few seconds.
Salas told me start with 10R 10W...
To low the voltage to 55VDC after the reg.
Is it CRC or RC configuration? From bridge to filter cap (+) just a resistor is RC. Is there a capacitor before the R?
It's CR so after PSU filter cap (+) the resistor & after connected the reg.
- Power Supplies
- The simplistic Salas low voltage shunt regulator
