Ah ok. Je suis le contraire. J'ai le Loxjie A30, mais je préfère le son des amplis TPA3255.
I think once more that is a question of taste.
I think that Infineon chips sound warmer than TPA325x chips. Spec Corp that is a famous Japanese firm is using Infineon chips in their $ 3500 best amps....
Both Merus and Tpa325X chips have a great thd+n figure but they sound totally different in term of "sound signature."
So is it the chip alone that determines the sound signature?I think once more that is a question of taste.
Im not talking about changing filters. And there is no pure direct mode on any DAC chip. You always need to choose 1 filter type.Personally ... on my Akm dac, I don't touch the filter, pure direct only.
Yes there’s 2x 2 channel chips. Each a different package type. 1 has the worlds best opamp after it that you can optionally add into the signal chain. Many different clocking schemes are possible, as well as power regulation schemes. And different ways to get the digital signal to the chip. And that doesn’t include the infinite ways it can be tuned in the internal firmware.It's an evaluation board ? How many channels ?
You re right. All counts, specially the caps, the OP amps, and implementation that surround the chip.
The best opamp is no opamp. You can also do that experiment on that EVM.
It is true, I remember when I bypassed the NC500MP Hypex OP amps (very simple to do by the way). It sounded fantastic BUT :
When you do so, you lower the input gain dramatically, so you need a good preamp to compensate for this....
The best DAC is NoDAC.The best opamp is no opamp. You can also do that experiment on that EVM.
Or 512 1 bit dacs in parallel per channel. Best way to do things I’ve heard yet.The best DAC is NoDAC.![]()
This is the objectivists forum!Having read the whole thread. Debates, ASR, chip model, measurements... Finally nobody here owns / has ever had a listen to this amp ?
- Class D
- Topping PA5 (TPA325X) : Is a modification worth it? ?
