What the heck? It's less than lunch!
Generally, I use only the volume pot/control that is on the unit when you buy it. Despite the popular notion from the pervasive everything-must-be-modified-camp that these are trash, I've never found that to be the case. I've experienced no channel imbalance, no noise, nothing detrimental at all. In short "If it ain't broke, don't fix it."
Sometimes I use my 6N3 "Sain Smart" brand tube buffer and turn the volume pot on the amp all the way up. Thus, relying on that volume pot to control the source volume.
Those $12 or so SMD (surface mounted device) type volume pots on eBay are quite nice. I've made several passives with those.
If you need the ability to switch to different sources, I highly recommend these inexpensive switch boxes.
MW
Please provide link to an SMD pot.
MW
