DAC AD1862: Almost THT, I2S input, NOS, R-2R
Buying oaps and transistors at ebay aliexpress is risky as said in the thread. Youcan try burson anssparkos discrete...discrete has advantage over oap fori/v
Also amount of h2 is pleasingfor ears..
But transistors must be paired. Have they diamond discrete oaps at burson or sparkos ? In case you have monney opa627 is one of the best choice here cause also its buffer...don t use sockett
Joined 2014
I’ve been using Burson V6 and V5 discrete opamps. I prefer these to any of the opamps I’ve tried so far. I also took a gamble and tried a pair of the China discrete opamps P03, garbage!! If you go this route, I’d recommend buying from reputable brands like Burson, Sparkos, etc...
Yes, you calculated it correctly.
Vrms = Vpp / (2 x 1.414) = 5.4 / 2.828 = 1.91
The output current from AD1862 is +-1mA, so the Vpp from basic I/V will be simply 2x resistor value (R8 or R9) in kiloOhm.
This is how the voltage output Vpp sine looks with 2k7 resistor:
It's slighty off topic. You should search for more understanding how to transfer an electric signal between a A point and a B point, google impedance adaptation both in current & voltage. What is interresting you here first is about voltage as you guessed. 1 V or less is ok in your case : just permitt to lower the Z of the I/V conversion... if you can hear the difference. You have to experiment to know. Theory is cool but practice is what you get & need at the end : experiment is your friend.
full output current from this DAC is +-1mA
resistor (Rx) in I/V converter is directly related to this output current and forms desired output voltage
Vp = 1 x Rx, thus Vpp = 2 x Rx
Vrms = Vp / 1.414 = Rx / 1.414
==> Rx = Vrms * 1.414 [Rx in kOhm]
if you consider the Vrms to be 1.228, Rx calculation is:
Rx = 1.228 * 1.414 = 1.736[kOhm]
the factor should be input sensitivity in an end device
if you have a passive preamp, go with higher Vrms to cover most end products input sensitivity
if the input sensitivity of an amplifier is 1Vrms (full power) then 1.2Vrms from DAC is enough, but if the amp has 2Vrms input sensitivity, then you need 2Vrms on your passive preamp ...
... 2k7 resistor in I/V should cover almost any device
... what is the input sensitivity of your amplifier or amplifier which will be used with this dac?
see it like this:
your 100W amp has 1Vrms input sensitivity (which is for full power output) ... 1Vrms = 100W ... 1Vrms from passive preamp means a linear potentiometer to be 100% open (you will have the full range of preamp to control the amp (0% - 100% == 0Vrms - 1Vrms))
if DAC is set to 2Vrms, then the linear potentiometer on your passive preamp can be open only 50% at max (preamp will set 1Vrms for amp to get full power, so you will have only half range of preamp to control the amp (0% - 50% == 0Vrms - 1Vrms) ... if you exceed the limit then your amplifier will be pushed to deliver more than its maximum 100W and this is the clipping)
but if the amp has 2Vrms input sensitivity (for 100W max), and your preamp can deliver only 1Vrms, then the output from this amplifier is only 50W
