I dont think this combo works in 'online' mode. To get it to work I had to use jumpers 2,3 &4 , leaving 10 and 11 open.Hi
I have finally assembled the dual AK4495 board with Pan. FM caps for dac and Silmic and AMCH caps for the analogue part with a NewclassD discrete opamp.
I have tried the AK4137 seperately and it was working with the another dac but when AK4495 is connected then no sound at all ...independent of output sample rate...
J02 on AK4137 is set and j10 and 11 is set on AK4495...
Any clues to the sound of silence?
Jo3 on the 4137 board is correct.
Ozcal: I hope that it does...that was the reason buying the combination...
Lehuy: I think you are right. I just say Kukynas picture with a direct connector which looked more neat instead of the cable..but now checking the AK4137 print and the AK4495 reference list on the Alipress then my setup is wrong...will connect cable to check
Ozcal: Sorry if I sounded a bit harsh...thanks for your input and in case the 20pin connector re-arrangement doesn't work then I will try the other jumper settings...are AK4137 and Dual AK4495 not supposed to work together according to jumper settings 10 and 11...those were specific for this combination as I understand??
This is a quote from the dual 4497 board sales page " The board then AK4137 board does not support inline control mode, you can use a non-integrated control mode with regard to the dual 4495 board."Ozcal: Sorry if I sounded a bit harsh...thanks for your input and in case the 20pin connector re-arrangement doesn't work then I will try the other jumper settings...are AK4137 and Dual AK4495 not supposed to work together according to jumper settings 10 and 11...those were specific for this combination as I understand??
I couldn't get any sound with jumpers 10 and 11 closed. I got sound with jumpers 2,3&4 closed and the sound was very good.
Strange that they have the jumper 10+11 settings then...which boards then works with AK4137 boards as controller?
could you guys check and connect only J9 instead of J10+J11? if it doesn't work another try is J9+J10+J11, thanks...
J08 and J09 does not exist on the Dual AK4495 that I have!!
However I have a J12 which is not explained anywhere
with J8 and J9 jumpers in pin config file he might be referring to J2 and J3 jumpers on AK4137 board, can you check configuration of those? I might be wrong but without trying it we might not find out...I sent him an email to clarify it but not sure when I get info back...
See picure of my setup in my post #120 (http://www.diyaudio.com/forums/digi...137-mcu-lcd-dac-kit-160-a-12.html#post4796660)
I have set J3 (I2S) and J10+11..I have also tried J2 and J10+11...no sound on my system
Tomorrow will play with system tomorrow..
Hi Daniel , will be ordering a new 4137 and Dual 4495 board today. It will take a few weeks to get it all built again taking shipping times into account but will report back if the new boards are any different to the first set I got.could you guys check and connect only J9 instead of J10+J11? if it doesn't work another try is J9+J10+J11, thanks...
The only way I could get sound out was to jumper 2,3&4 on the 4495 board with J3 closed on the 4137.
I ordered one of the 4118 boards that was designed specifically for the dual 4495 board but no matter what the setting could not get any sound.
See post 119 re : J12J08 and J09 does not exist on the Dual AK4495 that I have!!
Hi Daniel , got a link to the latest model please?Hi Gordon,
are you going to order the latest model of AK4137?
Daniel
Thanks Daniel , found it on Aliexpress also and order one and new dac today.
Have found some quality power supplies here :
K&K Audio | Digital Audio almost at the bottom of the page and will order those soon too.
digital part of the DAC 0.8uV Ultralow noise DAC power supply regulator 3.3/5/7V 1.5A*x2 - DIYINHK
opamp stage 4.17uV Ultralow noise DAC power supply regulator +-12/15V 1A - DIYINHK
these have 2x switchable rails per each board so 4 PSUs/regulators in total, you won't find better cost/performance ratio...
shipping is + 10USD total
Yes I use those as well. Fast delivery as well.
- Digital Line Level
- Dual mono AK4495S with AK4137 and MCU/LCD DAC kit for $160
