Terry do a listening test to Kypton-v
Hi Thimios,
I tried the Krypton with the latest changes. Bad oscillation and surging. I didn't have time to trouble shoot. I will try again after the holiday.
I also listened to the Eyesee. Very underwhelming. The output is low so that may have something to do with it. I will look into that after the holiday as well.
Blessings, Terry
My friend, this problem is yours .Krypton-v is rock stable(tested).Hi Thimios,
Blessings, Terry
Eyesee is a working IPS also.
Sorry Terry ,i mean that problem isn't at designing.Yes, my problem, not yours. Eyesee works, just underwhelming.
I will have to look it over. I may have csp hooked up incorrectly now that i removed the super pair.
My bad English.....
Yes, I know yours works. I haven't had time to trouble shoot. I didn't think about the CSP until now. I'm in bed so will have to check later. Same with Eyesee. It probably needs some adjustment. I didn't have time today. We have been very busy with the new grand baby and the holiday. I'll try to sneak some time to investigate.
Edit;
It was bugging me so I went out and got a board. Csp's are correct so It must be something else. I'll report back when I've found the problem.
Edit;
You better stock up. On Semi TO92s are obsolete. I've always preferred their products too.I use OnSemi BC5xx because they are faster at RF in a subltle way that sometimes improves stability, although for most circuits it probably doesn't matter.
Spring for a Luxo with the extra dioptre and SMT is easy. I like the look of through hole devices though.
But imagine some of the 80+ device IPS's (kyptonV , spooky) on 76 X 50mm
"mini IPS's". The low Ic of my IPS's makes for perfect SMD creations.
Some passives would still be through-hole (big caps).
PS - I chose my IPS's .... Spooky and wolverines for main stereo use (i'll compare),
and the symasui for the sub. Using my 2sa1673/sc4388's for the sub - lower Ft (20mhz) but higher SOA than the 0281/0302's - 4 pair for each of the 3 amps.
Stuffin' away (while eating stuffing ) - had most of the OPS devices.
OS
Edit;
Congrats on grandchild , terry !!
Hey ... we need to "slow down". I'm sure it's as hard to build 2 new amps a month
as it is to to design 2. I intend to be much more careful on any "blind" design.
BUT , soon I will have "sight" with my new testing jig (the 4th unused slewmonster).
OS
Me too!Congrats on grandchild , terry !!
OS
It is time for "slow down"
I have a big difference measuring voltage on Wolverine IPS and i want your advice,i report again about this.
We need an smd board designerNo better time than now to go SMD.
OS
Me too!
Of ALL the IPS's , Wolverine is fully CCS based .... should be the most rail
independant , "locked in" circuit of them all. (thermally , as well).
OS
Don't be affraid by SMDs. They can offer a lot of advantages*, and no problem with a good glass magnifier and some habit for the welding.My ancient eyes will not permit such strenuous activity at this juncture in life.
*Better parts, less parasitic inductances and capacitances, less box volumes.
If Ostripper came up with Jfet input like BF862 or j209, maybe i will make smd board
I have redraw CFA-X BV Mod, Eyesee, Kypton C and Kypton V using Eagle.
You have redraw these for smd devieces?If Ostripper came up with Jfet input like BF862 or j209, maybe i will make smd board
- Slewmaster - CFA vs. VFA "Rumble"
